Tuning-Kosten
OTTEC GT
Nice&Easy
Tough&Hot
1 Steuergerät, MAP-Sensor, IAT-Sensor AEM EMS2 Kit http://www.ninjaperformance.com/aem-ems-series-6311-1991-1997-3000gt-stealth-with-aem-sensor-kit-p-2082.html 1 $1.963,84
2 Benzindruck-Regler http://www.ninjaperformance.com/aem-high-volume-adjustable-fpr-black-303bk-p-1146.html 1 $142,56
4 Boost-Control-Ventil Für AEM EMS2 oder andere http://www.ninjaperformance.com/aem-boost-control-solenoid-kit-2400-p-2146.html 1 $99,21
5 O2 wideband sensor und controller empfehle eher 30-0310 http://www.ninjaperformance.com/aem-inline-wideband-uego-controller-kit-2310-p-1871.html 2 $203,70
6 Anzeige universal (AEM) Optional wenn man was sehen will http://www.ninjaperformance.com/aem-serial-data-stream-gauge-4300-p-1874.html 1 $203,95
7 Benzinpumpe (Walbro oder Denso) http://www.ninjaperformance.com/walbro-tank-pump-and-filter-kit-3000gtstealth-p-2039.html 1 $99,99
8 K&N 57i Luftfilter FIPK ist ganz ähnlich. Evtl. in DE teurer. http://www.ninjaperformance.com/advanced_search_result.php?keywords=FIPK&x=0&y=0 1 $159,59
12 MSD Zündkabel (Kit) eventuell in Schwarz http://www.ninjaperformance.com/msd-85mm-superconductor-32709-spark-plug-wires-6g72-dohc-p-832.html 1 $109,99
14 HKS DLI2 Zündverstärker http://www.ninjaperformance.com/hks-twin-power-dli-43001-ak001-p-2032.html 1 $429,99
15 CXRacing Verrohrung für LLK 1 $500,00
17 EGT-Adapter (auf 5V) mit Sensoren (Kit) Bei Ebay unter "EGT-Dual-K-Type-Thermocouple-Convertor" 1 $188,95
18 Einspritzdüsen 750cc/min Kit mit 6 Stück https://www.3sx.com/fuel-injectors-rc-engineering-370cc-550cc-750cc-1000cc-rc-injectors-mitsubishi-style-3000gt-stealth 1 $524,95
19 Turbolader ähnlich IPS Stage 1 TD04-19T 1 $2.850,00
21 Kabelbaum-Adapter Zum einfacheren Löten (gibt’s auch woanders) https://www.3sx.com/ecu-wiring-harness-adapter 1 $199,95
22 Fuel Rails optional https://www.3sx.com/fuel-rails-3sx-custom-aluminum-3000gt-stealth-6g72-6g74 1 $134,95
23 Fuel Loop Für 3sx custom rails; unbedingt so ankreuzen! https://www.3sx.com/fuel-rail-adapter-kit-fuel-loop-3000gt-stealth-for-stock-fuel-rails 1 $20,00
24 Verstärkte Motorbefestigungen in schwarz/blau/rot https://www.3sx.com/3sx-custom-polyurethane-motor-mounts-engine-mounts-3000gt-stealth-all-yearsmodels $279,00
